Crankshaft pulley
  • Thread starter Thread starter Begizzle
  • Start date Start date Apr 14, 2007
Begizzle
49
  • Apr 14, 2007
I got a set of march underdrive pulleys. I've installed the crankshaft pulley twice now and can't get it to spin perfectly straight. It wobbles a little bit. Is this a problem and what am I doing wrong?
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Apr 15, 2007
  • Apr 15, 2007
It may just do that slighty,try getting a new spacer (get a Ford one,dont buy thous cheap ass Profesional Products trash ones they dont line up nearly as well).
Begizzle
49
  • Apr 17, 2007
Where is the spacer? I thought that the crank pulley bolted directly to the harmonic balancer.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 17, 2007
  • Apr 17, 2007
The Ford OEM balancer does. Aftermarket balancers use a spacer to make them fit on many different cars.
Plan on having charging problems and possibly overheating problems using the underdrive pulleys. A different radiator and alternator are often needed to fix the problems the underdrive pulleys create. If you want maximum reliability from the car, look elsewhere for ways to make extra power. An electric fan will increase the HP about the same as the underdrive pulleys, but without the problems associated with them.
On a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should or if you have an electric fan. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD and you will need the u-joint, part #353 from NAPA. It should bolt right up after the u-joint swap.
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
fiveohwblow
Official Member
2,169
145
155
Apr 17, 2007
  • Apr 17, 2007
I only had charging problems with my stock equipment at night when I was running lights, stereo, and or heater. Other than that, your car needs only enough charge to spark the ignition and run brake lights etc... Good mod IMHO and have done it to well over ten cars without problems. You will want to eventually do all the other expensive mods previously mentioned but UDP are a great bang for the buck.
Were the pulleys used or new?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Apr 17, 2007
  • Apr 17, 2007
I would never do underdrive pulleys again except for 93 cobra pulleys
93tealstang
1,242
McSherrystown/Hanover Pennsylvania
Apr 17, 2007
  • Apr 17, 2007
Same here, killed two different batteries running underdrives. F-dat.....
fiveohwblow
Official Member
2,169
145
155
Apr 17, 2007
  • Apr 17, 2007
Thats crazy we had such different experiences... I have kept the same battery for four years of owning the vehicle, all with UDP's on....
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 17, 2007
  • Apr 17, 2007
It is a function of where you live and the weather, and traffic conditions. Live in Maine, drive durning the daylight hours in dry weather with no stop and go traffic and you will have no problems. Live in a big city in the south, southwest or desert west and you can expect trouble. Add heavy traffic, heat and humidity and watch the coolant temp rise and the battery voltage fall.
93tealstang
1,242
Apr 17, 2007
#10
  • Apr 17, 2007
  • #10
My car simply rejects underdrives. Stop and go type traffic, stereo, and driving at night alot are mainly what caused my battery failure. Bolted stockers back on and haven't experienced even the slightest of problems.
I've heard guys saying they've ran them for years without problems, it baffles me just as it does you that I can't run them.
fiveohwblow
Official Member
2,169
145
155
Apr 19, 2007
#11
  • Apr 19, 2007
  • #11
That definitely makes sense and I agree those will add duress to any strained system. Three of the four years of owning the vehicle I was in the high desert and was always running ac... I guess as the last poster put it its just baffling... I say it never hurts to try in the end becuase you can reverse it. If your battery dies after using them for a short amount of time, chalk it up to the cost of the hobby, but in all reality if that is all it takes to kill your battery then you were in the running for a new batt or alt. anyways...
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Apr 19, 2007
#12
  • Apr 19, 2007
  • #12
Since we're on the top, what does everyone thing the best brand of pulley's are?
93tealstang
1,242
Apr 19, 2007
#13
  • Apr 19, 2007
  • #13
Pullies are pullies no matter what brand, they all do the same thing. Lots of guys running them usually have ASP or March's.
fiveohwblow
Official Member
2,169
145
155
Apr 19, 2007
#14
  • Apr 19, 2007
  • #14
March has the best reputation and for a good reason, however I have always installed Mac and done very well.
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
C
Vortech water pump and tensioner pulley issue
  • Crooner88
  • Feb 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
