Crazy Clutch
  • Thread starter Thread starter CornerCarvin67
  • Start date Start date Apr 25, 2005
CornerCarvin67
246
  • Apr 25, 2005
Okay... this is crazy.... but it's the kind of thing that makes me lose sleep at night. I put
my clutch and pressure plate on last week. And for some reason I keep wondering if I put
it in correctly. I should just pull it all back off and verify it... but it's a pain pulling it off the
flywheel and going thru all that again. The clutch has a sticker showing which side goes
to the flywheel... but I was just wondering when I put the pieces on the spare yoke I was
using for alignment whether I accidentally flipped it backwards. I don't think I did... but how
can I be sure? Could have the assembly still gone together if it were backwards? Are there
any tell tale signs of it being right or wrong? The car is just sitting on stand at the moment
as I wait to pick up the bell and tranny this week. I notice that when tightening the pressure
plate bolts that the fingers on the pressure plate were moving to a tighter position around
the axis of the yoke. Should I read any indication off of that? Was that just an indication
that the clutch was being properly set into it's proper position?
I'm just trying to avoid yanking it all back off... that's all. If I wasn't waiting around for the
tranny I would have just put it all together and not thought twice....
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 25, 2005
  • Apr 25, 2005
I'm thinking you have it on backwards. (In my case, if there's a 50/50 chance of getting it right, about 80% of the time I get it wrong, )
On my solid hub, 6 puck clutch disc, the hub isn't centered on the disc in the linear plane, it's offset to one side (but I don't remember which side, front or rear).
I guess I'm saying if it looks or feels different, chances are it is.
Larry
N
nds03
166
  • Apr 25, 2005
take it back off to be sure
R
ron67fb
1,117
SF Bay area, CA
Apr 26, 2005
  • Apr 26, 2005
The fingers shouldn't move when tightening the bolts. Look at the center hub, usually there is "engine side" stamped on it in tiny letters.
CornerCarvin67
246
  • Apr 27, 2005
Quick update:
I took off the pressure plate and looked at the direction I had the clutch. I had it right the first time. And for the record... the pressure plate fingers DO move when final tightening and postioning. Also, because of the clutch hub.... it would not have been possible to put it in backwards. The hub hits the flywheel.
Just FYI....
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 27, 2005
  • Apr 27, 2005
Brain fart, you're right. I was thinking when you said it had a sticker saying which way it went, none of mine ever had that. I always figured it out because it could only go on one way. Crap, I'm getting old!!! It has been about 8 years since I messed with it though.
R
ron67fb
1,117
SF Bay area, CA
Apr 27, 2005
  • Apr 27, 2005
CornerCarvin67 said:
Quick update:
Just FYI....
Now that it's morning, it makes more sense to me. I should stop posting past my bedtime.
CornerCarvin67
246
  • Apr 27, 2005
Guys.. no worries. None of us were sure. That's why we come here.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 27, 2005
  • Apr 27, 2005
Yeah, but I hate that you had to go into it again. I shoulda remembered.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
