Creaking sound from front drivers side…
85GTKid
511
Oregon
If i push down on the drivers side front the car makes a loud creakin noise in that are and i can also hear it slightly over my exhause when driving and i hit bumps. What would cause this? Struts and springs are only a year old. Possible the strut is going bad?
Could be your struts, but it's more likely your ball joints. The OEM ball joints have no grease fittings, and can run dry and creak after a number of years.
Do you hear any creaking when turning the front wheels, as well as when you go over bumps? If you do, it might be a sign that the ball joint needs lubrication/replacement.
thanks this far. anyone else? I have done many things to my car but never the joints....expensive to have done? what do you mean by the tie rod ends? do they need lubed also?
the ball joints have to be pressed out of the lower control arms. When I had to do mine and I called around for prices the ball joints were expensive for some reason but I called Ford and believe it or not they sell the whole lower control arm with the ball joint cheaper than the ball joint alone! They are kind of a pita to change but I would suggest that you call upFord and find prices for the whole lower control arm, that way you don't have to press it. By the the way I'm pretty sure it's your ball joints. I f you want to double check, get a long pry bar or screw driver and place the steel end to the ball joint and hold the plastic part to your ear, have a buddy push it up and down, this will act as a stethoscope and your can hear if the squeaking is coming from the joint
