The good old Grand Sport. I have only seen 4 of those in my life......a long time ago....3 of them were on the back of a tow truck.
Kurt
Kurt
Too funny!
I was just about to post "at least she didn't want a Miata".
Looks like a real clean car.
I like women that are strong enough to buy and drive an American V8 sports car.
And check this out too. The thing has all stock exhaust still. She doesn't like it. She wants it LOUDER!
C4 ZR1 has a glorified outboard motor. Fitting.I don't blame her. Stock C4's always sounded like glorified 4-stroke out board motors. lol
C4 ZR1 has a glorified outboard motor. Fitting.![]()
Yeah, we had a guy around here with a '90. I remember seeing the back tires on it thinking (these have to be the widest tires I've ever seen on a street car)....which at the time, they probably were. Come to think of it, he did end up having a lot of issues with it and selling it after a few short years. He said it used about a liter of oil per month on top of it all.Designed by Lotus and built by Mercury.
Back when the those ZR1's came out somebody in our little town bought one. At the time my uncle was the service manager for our local Chevy dealer. Said it only left the service dept occasionally only to return in a few days/weeks with something else wrong with it. I beleive it was the first year of production for them, so that could explain some of the lack of reliability. Not sure if subsiquent years got better.
That's right....their engines were built by Mercruiser if I rectal? I'd still give my left nut for one though.
Please. There will be none of this rectal talk allowed.
But wht? I though Corvette's and assholes went hand in hand with one and other?
But why? I though Corvette's and assholes went hand in hand with one and other?
I've always known that to be a Porsche joke. It works though!
I remember talking to the Corvette product manager about the old OHC ZR1. He said it was a massive face palm moment for GM. Every time they had to warranty out an engine on one of those, it cost GM $32,000. That's why they never pursued building other OHC V8s after that one.
Kurt
They did pretty well with the Northstar Series DOHC V8 engines in the Caddy's? Those suckers were around nearly 20-years?![]()
I heard the Northstar's were not without problems too. Never owned one but that's what I heard.
N* engines? ROFLMAO.. I had an 02 DTS. 50K POS that spent more time me fixing than driving. That motor had NO reason belonging in that car. A "race" motor- aluminum with steel sleeves- Besides designed to use a quart of oil every 1000 miles, they are known to lift the heads at anywhere from 60k miles on due to another GM quality design flaw- the head bolts pitch and count was not not strong enough. Doesn't matter how you baby the car. Ask me how I know. At 90K miles, sure enough my heads started to lift- overheated and exhaust in the coolant. And you have to pull the motor out to repair- drill out the head bolt holes, retap with a special jig and replace with inserts and stronger bolts. About a 3k-5k job at a shop if you can't do it yourself.
That and the rubber intake plenums that rip, the water pump drive belts that sieze, the starter that is under the intake manifold and fail, the blowby problems do to the low tension rings and engine design, the coolant tubes that clog, the smog valves located at the lower firewall that fail and you can't get to without going from underneath the car, and the fact the engine is modular and in two pieces and leaks oil out of every seal and sensor eventually- it's a great engine. Google Northstar head gasket failure and prepare to see 100's of posts about the POS.
Did I forget to mention the "pop and drop" window regulators? All four window regulators replaced usually every year as they use a cheap plastic clip to hold the cable. Good thing I could replace them and the part was $30, The dealer wanted $600 a pop to replace. Got so good at it, I could do a window in 40 minutes.
Or the HVAC door motor under the dash that fails- $100 part and you have to replace it by spending an hour upside down under the driver side dash. Or the blower motors that fail- $200 and yep- another 2 hours upside down under the passenger side dash.
Then there's the electronic air ride suspension- the motors fail, the shocks need replacement- only $1000 if you want to replace with GM parts.
That was my last time ever buying a GM product.
Rant off.........![]()
