Crown Victoria motor in a Mustang
StangGT96
94
El Paso, TX
Well finding a GT motor is harder thatn i thought! Is the block the same? Such as the pistons, crank, well basically the rotating assembly. My plan is to use a Crown Vic block with the PI heads and intake manifold. Also i want to increase the compression just like a nonpi motor with pi heads, can it be done on a Crown Vic
The thing is that I only found a couple and they want alot of money for it and its nonpi. i found a block (from a crown victoria) with crank, rods, and pistons for close to nothing. My plans are to rebuild and use pi heads and so on. Like i said are you crank, rods, and pistons the same? How about the water and oil pump? How can I know if its a Crown Victoria, Cougar, or Grand Marqui block?
