streetmod
Eccentric eliminators
Snail50, I have the eliminators on my 69' and they probably do a better job than the stock style. But keep in mind that all they do is replace the stock bolts. They do not fix bump steer, unless you are lucky enough to have your LCAs perfectly centered in to frame hole, and if I remember the eliminator kit DOESN'T have holes in the center, they are all offset in degrees to be able to achieve various camber settings by rotating the square washers.
