  • 1994 - 1995 Specific Tech
custom tune?
  • Thread starter Thread starter amplifier28
  • Start date Start date Jan 14, 2009
1 of 2 Next Last
amplifier28
222
  • Jan 14, 2009
will a custom tune be necessary if an aftermarket intake manifold and throttle body is installed on a 94 gt?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 14, 2009
  • Jan 14, 2009
No
Grady
MysteryMachine
1,835
Parkesburg, PA
Jan 14, 2009
  • Jan 14, 2009
nope
ProKiller
3,064
15
78
PA
Jan 15, 2009
  • Jan 15, 2009
YES!
wait actually no
Stanger007
2,015
Baton Rouge, LA
Jan 16, 2009
  • Jan 16, 2009
Nope but you will have to be sure to setup the throttlebody to factory specs to achieve the proper airflow. Usually 1.5 turns up from bottom on the ISC bleed and 1 turn past 0.010" clearance on the TB arm screw will get you here.
I tuned a 342 last nite with 75MM throttlebody, X cam, Holley intake and with the aid of being able to see ISC learning etc I was able to properly set his TB without even having to touch the neutral idle airflow function.
Also if your fueling is incorrect at idle you will chase your tail.
Wes
amplifier28
222
  • Jan 17, 2009
no custom tune is needed with an air intake, throttle body and intake manifold swap? will the swap give me any real performance upgrade? i also plan to swap out the rear end gears for some 4.10 or 3.73 since my vert is an automatic.
Stanger007
2,015
Baton Rouge, LA
Jan 17, 2009
  • Jan 17, 2009
You will see an increased topend with those changes.
For the gears you will likely want a custom tune to lower the shifting RPMs of the transmission so that you do not nick the rev limiter. The stock transmission typically does not shift fast enough with the increased RPM rise that gears give you.
Wes
amplifier28
222
  • Jan 17, 2009
will a tune be necessary with 3.73 gears?
Stanger007
2,015
Baton Rouge, LA
Jan 17, 2009
  • Jan 17, 2009
It'll be close, if you've got the U4P0 processor you will be more apt to get away with it than if you've got the W4H0. You can pop off the passenger side kick panel and read the teartag on the PCM to see what you've got.
Depending on the power of your motor, age of the transmission etc it is a bit different for everyone.
Wes
amplifier28
222
#10
  • Jan 18, 2009
  • #10
anybody else has experience with a rear end gear swap? will a custom tune be necessary if i have a 3.73 ratio gears installed in my auto tranny stang? how about 3.55 ratio gears? info greatly appreciated. thanks in advance!
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 18, 2009
#11
  • Jan 18, 2009
  • #11
You don't need a tune for a gear swap. On a stock 5.0 you never shift anywhere near the rev limiter even with a gear.
Kurt
HISSIN50
34
129
Jan 18, 2009
#12
  • Jan 18, 2009
  • #12
You'll be very hard-pressed to find any information that is better than that from Wes, a professional tuner.
Every car is different, which is why tunes are custom. No one can tell you for sure how your car will react, as no two react the same. There is a LOT that can be done in the tune to clean up the AODE performance, and accomodating the shift thresholds is a part of that.
Good luck.
T
tstang21
219
#13
  • Jan 19, 2009
  • #13
amplifier28 said:
anybody else has experience with a rear end gear swap? will a custom tune be necessary if i have a 3.73 ratio gears installed in my auto tranny stang? how about 3.55 ratio gears? info greatly appreciated. thanks in advance![
i love my 373s. youll feel a big difference but since your auto, 410s will be amazing. its like you bolted on loads of power. looks into a torque converter. its another adder that youll find that makes a difference.
as for the intake, you wont need a tune. the computer will learn it.
amplifier28
222
#14
  • Jan 24, 2009
  • #14
anybody else with experience on a rear end gear swap on their auto tranny stangs? did you get a custom tune?
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 24, 2009
#15
  • Jan 24, 2009
  • #15
Dude seriously. You won't need a tune with a gear swap. I might not know a whole lot, but you can take that to the bank.
Kurt
Venom351R
4,548
41
98
MAINE
Jan 25, 2009
#16
  • Jan 25, 2009
  • #16
several people have answered your question more the once. You dont need a tune w/ a gear swap no matter what gears you put in or what kind of transmission you have.
HISSIN50
34
129
Jan 25, 2009
#17
  • Jan 25, 2009
  • #17
Once again, you CAN have issues with the limiter on an AODE/4.10 car. You can even have isses with a lightly modded 3.73/AODE car. Not to mention that if you're near the limiter, you've probably fallen off the powerband anyhow.
If all you guys were not having issues and the higher shift points were not bothersome, something was probably wrong with your power output.
amplifier28
222
#18
  • Jan 26, 2009
  • #18
i want to install gears but i wont if a custom tune is needed.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Jan 26, 2009
#19
  • Jan 26, 2009
  • #19
YOU DO NOT NEED A TUNE
Black95GTS
1,644
Marlborough, MA
Jan 27, 2009
#20
  • Jan 27, 2009
  • #20
I think you need a tune on a completely stock 5.0. Thats just my $.02.
thanks,
Adam
1 of 2 Next Last
M
Iac valve
  • Mike3
  • Aug 8, 2025
1994 - 1995 Specific Tech Aug 11, 2025
AeroCoupe
F
Drivetrain TKX Shifter Position Question
  • fasterthangas
  • May 29, 2026
  • 2 3
1994 - 1995 Specific Tech Jul 4, 2026
WhiteCobra95
M
94 Mustang gt throttle body
  • Mike3
  • Jul 26, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
