Yeaht the sensor would be easy enough (just use one), the IAC may just be left on one too. But it almost seems like you would have to stick with speed density, which I currentl have. In that case you are limited with power oput anyway so the extra airflow doesnt even make sense.
Here's what I was thinking of doing if it would all fit.
Make a custom intake that has the tb's on top and make a custom bonnet that has a tube running to the mass air and filiter with a k and n before the mass air.
Or
Build a intake with two tb's on the front over the distributor (gulp, like a ls1) and then run a tube to the meter.
Or
Build a intake with both tb's coming off the back and run a tube into the cowl where the filter and mass air would be stashed if it could all clear the wipers.
I just like being different, I want everything on my car custom or one-off. I will be running nitrous, and I dont plan on installing a blower. Plus if a use a heavily ported stock lower I can get the whole thing to flow arund 200 cfm. If it doesn't all work well I can just toss my other intake back on and it's no biggie. It look killer for car shows though, if I can pull it off. I like the idea of putting the TB in the back the best but idon't know if there is enough room to fit them in. obviously the smog crap is gone already.
