Hey guy i was cutting out my floor in the passanger side, i was using a jig saw and i cut the fuel line, what should i do should i just put a piece of rubber hose in the line to fix the cut?
thanks
do that or get a piece of hard line about the same diameter as the inside wall of the fuel line, then clamp it back together. how long is the piece? would it be that much trouble to replace the whole section of hose? that would be the best fix so you could ensure no leaks
