i have a 87 gt vert did a heart transplant from a 5.0 to a 5.8 that is now a 358 it has a 750 speed deamon vitor jr intake comp cam 280h .030 speed pro pistons,pa super comp c4 tranny& 3800 tci torque,the problem at idle its fine but when u drive it it cuts out& breaks up at mid to high rpm,it sas the stock in tank pump,put a holley pressure regulator on it with 1 feed 1 return 1 to the carb,but cant get the reg to adjust the pressure. with out the return hooked up it drowns the carb out, with the return hooked up the only way it builds pressure is if you kink the line partly shut,could this be my cut out/break up, and if so how does every one do this while still using the stock pump, any help
