Cutting Driveshaft
  • Thread starter Thread starter Rmoore45
  • Start date Start date Jul 17, 2011
R
Rmoore45
142
Jul 17, 2011
  • Jul 17, 2011
I'm installing a T-5 into my '67 coupe, I got to the point where I have to put in the driveshaft. Its too long How do I go about measuring so that I can get it cut?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jul 17, 2011
  • Jul 17, 2011
Interesting. At least 90% of the time no cutting is required. Welcome to that 10%.
Put the back end of the car on jack stands with the axle hanging all the way down, tires in the air. insert the slip yoke all the way in the trans, then pull back out 1/4". Measure the center of the front U joint cap to the center of the rear joint cap.
R
Rmoore45
142
Jul 17, 2011
  • Jul 17, 2011
I put it on my lift and had the yoke stick out 1/4", from center to center it was 50 and 3/8". My driveshaft is 51", 5/8" too big.
zookeeper
3,415
63
109
Rogue River, Oregon
Jul 17, 2011
  • Jul 17, 2011
If you measure it that way (full droop) when the suspension compresses, you're drive shaft is quite likely to go into the trans too far, bottoming it out and damaging the trans. I always measure it with the axle stands under the axle so the springs support the car's weight. BTW, the T5 is about 3/4" longer from block to seal, so while you may be safe with 5/8" off your stocker, better measure at least twice.
R
Rmoore45
142
Jul 17, 2011
  • Jul 17, 2011
I also thought that if I measure with full droop that when its back on the ground the driveshaft would actually go into the trans, however that's not the case. With the car on the lift (full droop), I measured the distance between the T-5 seal and the pinion yoke and got 53". Then I put the car on the ground and bounced it around and let it settle down, I took the same measurement and got 53 and 1/2". So the axle actually moves further away from the trans as the suspension compresses because of how the leaf springs are attached to the car. I thought that was pretty cool when I measured it and figured out how it worked.
I was thinking about just rounding up to make it easier and just cut 3/4", now that I know the trans is 3/4" longer I probably will. Thanks
2+2GT
3,333
10
79
Jul 18, 2011
  • Jul 18, 2011
Rmoore is right, the yoke slides OUT of the trans as the suspension compresses.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 3:55 AM
manicmechanic007
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
