  • 1994 - 1995 Specific Tech
Cutting out.
  • Thread starter Thread starter 95BLKGT5.0
  • Start date Start date Sep 1, 2007
95BLKGT5.0
608
Auburn Washington
Sep 1, 2007
  • Sep 1, 2007
My car intermittently cuts out(not a simple miss fire) it does it while accelerating or just cruising. I checked all the ground wires and dist. and coil wires. All look good. Any one have any idea whats causing it.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 1, 2007
  • Sep 1, 2007
Usually when the engine cuts out intermittently, it's the TFI or PIP. You got any codes by chance?
BlackVert
5,589
9
98
Bethesda, MD
Sep 1, 2007
  • Sep 1, 2007
+1 on the pip. they are known to go in our cars. the classic symptom of it is that it cuts out, and then after you let it sit a while, it is ok again, until it cuts out again. the heat over time causes them to fail. that is why letting it sit a few minutes helps, because they cool off. i think a "work around" i have heard is you can take the cap off and spray something down in the dizzy to help it cool faster ... but i don't remember what they say to spray, something like brake or carb cleaner
it is in the distributor, and a pain to replace. most people just get a new distributor
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 1, 2007
  • Sep 1, 2007
Are you losing all electrical power when the engine cuts out?
If no, I'd say it's the PIP sensor. If yes, check the battery terminals and make sure they're tight on the battery posts.
stang_95gt
  • Sep 1, 2007
i'm having the exact same problem on mine. After about 20 min or so of driving it starts missing or cutting out at about 4,000 and after about 30min it'll do it cruising. I've checked fuel pressure ignition coil, wires and plugs with no luck. Whats PIP stand for?
BlackVert
5,589
9
98
Bethesda, MD
Sep 1, 2007
  • Sep 1, 2007
Profile Ignition Pickup. Also known as the Hall Efffect Sensor. It's in the distributor
stang_95gt
  • Sep 2, 2007
i changed the sensor on mine today and i'm still having the same problem.
94 kill switch wire question
  • MrPerfect2
  • Dec 11, 2025
1994 - 1995 Specific Tech Jan 10, 2026
fasterthangas
F
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
