Cylinder 1 misfire after pi swap.
tomustang
Psychotic Member
3,434
McLean Hospital
after the swap the car runs great, it's got alot more power on the upper end. i took it to autozone today and they pulled the the code for cyl 1 misfire. i've checked the wires and the plug. it's all good. i'm leaning tward the the fuel injector. i don't know. any ideas?
i did the swap over a month ago. the electrical is fine. i guess i had the code since then. like i said it runs like a champ though. i had it pulled from autozone, i think it read lean too. i'm gonna go back over and see how much a single injector is.
tomustang said:
they're .055 all around but just 1 cylinder is bad, how would that be? before exhaust i got PI heads and a ported intake
Because cars are funny like that. Mine did the same thing when I did my head swap and used the stock spark plugs and stock gap. I replaced then with a 1 step colder plug and decreased the gap and I wasnt getting the cylinder miss fire code.
so a smaller gap for headswapped cars will make more power? i might try that. are u using copper or platinum plugs?
also, before you buy a new injector, just swap 2 of them and see if the misfire switches the other cylinder.
wont make more power. When you have more air flowing into the cylinder and with a large gap, that extra air in the cylinder sometimes can disrupt the igniting of the air/fuel.
oh yeah. :hail2: to mogs01gt for that power increase. very very noticeable. ill try the injector switch.
