D&D motorsports
90sting
193
laf la.
does anyone here has a block from d&d motor sports?
if so what kind of company are they? and how do you like the motor?
they have a 331 long block that put's out 425 hp
for $4200.00.
They use stock blocks unless you purchase a DART or FORD RACING block. Why not buy a kit and have it installed and machined by a local machine shop, it would save you money.
Example $1500 for a good stroker kit, $500 in total machine work needed, maybe $200-$400 in assembly.
it's a long block 331 they said that the 331 dyno @ 425 h.p
and for $4200.00 that does not sound bad
if i was to buy a short block ,heads, custom cam,and all the time to put it togather it would cost more then buying the long block.
this is whats in the long block
1.new comp preped block
2.5140 forged steel crank
3.4340 forged h-beam rods
4.forged probe pistions
5.molly rings and clevite bearings
6.afp fasteners
7.302 main support
8.h.v. oil pump
9.balancer and flywheel
10.billet timing set
11.fel-pro gasket set
12.tfs alum heads or pro-topline
13.motorsport hyd roller lifters
14.hyd roller assembly
15.manley push rods
16.scorpion roller rockers
17.engine is balanced , blueprinted,comp assembled
331 @ 425 hp.
what do you'll think
6.afp fasteners
7.302 main support
8.h.v. oil pump
15.manley push rods
331 @ 425 hp.
What brand are the rods and crank, balancer and flywheel
TIMMY2734 said:
With motors and high hp applications, you tend to get what you pay for.
so what are you saying is this not a good deal or to good of a deal?
and for the other question iam calling them monday morning
to find out more , and iam going to ask about the crank, flywheel,
blancer,rods.
Here is what I would build.....I used your list my comments beside it
2.5140 forged steel crank (4340 Forged crank is more common and stronger)
(331 or 347 stroker kit, Scat H-beams 4340, Scat 4340 crank, rings, bearings, Probe SRS series pistons, all ARP hardware $1500)
6.afp fasteners ($100 for ARP head studs)
7.302 main support ( $300 DSS support comes with ARP main studs)
8.h.v. oil pump ($60 including hardened shaft)
9.balancer and flywheel ($238 Romac, $300 for a SPEC flywheel)
10.billet timing set ($100 for a Crane or Rollmaster)
11.fel-pro gasket set (For a shortblock you need about $80-100 in gaskets)
12.tfs alum heads or pro-topline ($1285 AFR 165's or 185's)
13.motorsport hyd roller lifters ($109 fms)
14.hyd roller assembly (Custom Cam FTI $325)
15.manley push rods ($100 for TFS chrome-moly 1 piece)
16.scorpion roller rockers ($200 1.6 ratio)
17.engine is balanced , blueprinted,comp assembled (Runs around $600 total)
Total.... $5317 so you can see $4200 is fairly cheap for what you listed. The biggest difference in my list is a 4340 crank +200 or more, FTI custom cam +100-150 over other, AFR heads +200, balancer and flywheel ( I picked 2 of the better names out there)
Add another $269 on for a good 7qt oil pan, pickup and dipstick, you'll need it to clear the high volume pump and girdle.
If the internals or any components are CAT stay away they are junk, usually if it was a good brand name they list who it is.....
