D*mn Turn Signals!!
  • Thread starter Thread starter 5.Slow93
  • Start date Start date May 25, 2004
5.Slow93
  • May 25, 2004
I need to get my car inspected and all of a sudden my turn signals stop working. How conveinent...........
My hazards work
My brake lights work
My park lights work
My head lights work
My turn signals................nope
Where is the turn signal relay. I was told the hazards are on a different relay, and that relay is on my fuse panel. I was also told the turn signal relay was on the pass side near the radio, and I dropped the glove box and removed the radio but I can't find it. Where the hell is this thing and what does it look like??
The Shape
2,224
East ARKANSAS Delta
May 25, 2004
  • May 25, 2004
Don't know about your '93 but on my '87 the turn signal flasher was way up under the dash above the steering column. I had to lay on my back in the floor board and shine a light around up in there to find. Then it was a complete pain getting my hand in there to it. It was plugged into a harness and the nipple on the end of the flasher was popped through a hole in bracket up there to keep it in place. After replaing it I just zip tied it under the dash to make it easier to acces next time.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 25, 2004
  • May 25, 2004
take out your fuse box and it should be on the back of it. i think its the round silver thing. my is sitting in my glove box because it wont stay in there...and my turn signals work great....go figure
91REDGT50L
9
Baytown, TX
May 26, 2004
  • May 26, 2004
Hey man, I had the same exact problem with my 91 GT. I can tell you exactly where it is. Go to the passanger side and where the center console is as it goes up. There should be an open space behind your radio. Stick your hand and you'll feel a round plastic relay right in the back, with a twist it should just come right out. It's actually a light green color relay. You could even see it if you had one of those handy shop mirrors on a stick or even if you stuck a flashlight underneath. The other guys are correct there is another relay for the hazards, but that fuse will go out way before that relay does. And if it's not your relay that's not messed up. I strongly suggest you look underneath your steering column and check your ignition harness. Sometimes the teeth that hold together the harness to the bracket breaks or becomes loose and you don't have a good connections to things. If you'd like a better explaination feel free to send me an e-mail and maybe I can send you pictures.
91REDGT50L
9
Baytown, TX
May 26, 2004
  • May 26, 2004
Oh i forgot to mention, it's not on the radio...it's actually below it.
(RADIO)
(RELAY-CLOSER TO PASS side)
5.Slow93
  • May 26, 2004
Sweet, I'll check it out when I get home. Some guys from another forum just told me the same thing you did.
I removed my radio and climate controls, got all up in that bitch with a light, still couldn't find it. I'm gonna try again when I get home today, I'm gonna find that bitch.
Thanks for your help!
flying high
1,835
colton ca
May 26, 2004
  • May 26, 2004
if u take of your glove box it will be easier to see.
M
Mizark347
145
Detroit
May 26, 2004
  • May 26, 2004
Flasher switch....round silver plug in the fuse box.
bt15
129
Oahu
May 26, 2004
  • May 26, 2004
For the '93s, it's near the back of the radio, not in the fuse block. I had to figure that out the hard way.
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
9
Electrical Hazards dont work - but turn signals do
  • 91EmeraldGT
  • Nov 17, 2024
Fox 5.0 Mustang Tech Nov 18, 2024
Mustang5L5
