I have changed my:
air filter
distributor
fuel filter
Checked my:
timing
fuel pressure
The car is popping, which causes a loss of power. It sounds like it may be coming from the intake or exaust, possibly both. Throttle response is gone. It is an intermittent problem, but the car is certainly not running as it was a few days ago. Until that time, the car ran fine, making a cross country trip a couple months ago.
I ran the fuel down pretty low coming home from work, which was when I noticed the first pop.
The idle seems to have decreased to about 650 RPM which is only an issue because it wouldn't get that low even when warm prior to the last few days.
I am going to go check the plugs for fouling or lean mixture, hopefully some ideas when I return. The only thing I can think of is an intake gasket leak (vacuum), and that takes ordering parts to fix.
Please help if you have had similar problems, and thanks for at least looking at the post.
air filter
distributor
fuel filter
Checked my:
timing
fuel pressure
