Dash bulbs don't work? Don't change them quite yet.
Mr_Q
721
Burbank, CA
I took my pod out and reseated each bulb after testing that each one DID work.
Apparently after 15 years of build up and corrosion they can short out but not BURN out.
Now they all work! Yay!
same thing also happens inside power window and power door lock switches the contacts within the switch builds up corosion so if your power locks or windows don't work usually you can remove the switch take it apart and clean contacts reassemble and reinstall and it will work. this is cheaper than replacing, i have used this method a couple of times...
