The other day, my fuse blew out for the dimmer switch. When this happened, all my dash lights quit working (gauge cluster, HVAC lights, Traction control, Rear defrost, fog lights). Well I just went and replaced the fuse. Well, I had the key out of the ignition and flipped on the lights to make sure they were working. I turn on the switch and the dinger starts going off, but none of the lights come on, then the dinger goes off. The fuse didnt blow again and the lights are still not working.
Also, the dome light is not working at all. I can turn the dimmer switch all the way to the left and click it over to turn it on and it does not work, and when the door is open it does not work. The door dinger DOES work if the key is in the ignition with the door open.
Any thoughts?????
Any thoughts?????
