9 93notchspray New Member Dec 25, 2003 87 0 0 blacklick ohio May 13, 2004 #1 May 13, 2004 #1 driving down the road and all of a sudden the dash lights go out. i heard a pop but cant figure out how to fix it. i checked fuses but i still cant get them to work. thanks jason
Z ZERO-7 New Member May 6, 2004 7 0 0 May 13, 2004 #2 May 13, 2004 #2 I would look into the dimmer switch & head light switch
9 93notchspray New Member Dec 25, 2003 87 0 0 blacklick ohio May 13, 2004 #3 May 13, 2004 #3 would that have anything to do with it?
Z ZERO-7 New Member May 6, 2004 7 0 0 May 13, 2004 #4 May 13, 2004 #4 yes abad dimmer switch can be the direct result of no dash lights
Juiced88Coupe Founding Member Aug 1, 2001 367 0 0 Austin, Texas May 13, 2004 #5 May 13, 2004 #5 ZERO-7 said: yes abad dimmer switch can be the direct result of no dash lights Click to expand... i had that happen on my 87, replaced dimmer switch and that fixed the problem, would not hurt to check the light switches however... Matt
9 93notchspray New Member Dec 25, 2003 87 0 0 blacklick ohio May 13, 2004 #6 May 13, 2004 #6 well guys i figured it out it was the 13 fuse. you guys rock. thanks
