  • SN95 4.6L Mustang Tech
Dash Squeak
  • Thread starter Thread starter dalton13
  • Start date Start date Jan 5, 2004
D
dalton13
18
Dallas, TX
Jan 5, 2004
  • Jan 5, 2004
My 2000 Saleen has the most annoying squeak in the dash, up close to the windshield. If I keep pressure on it downward, it seems to go away. Somedays it is worse than others. I don't have a strut tower brace, and I have heard this may be part of the problem. Any other ideas?
brando
28
Alabama
Jan 5, 2004
  • Jan 5, 2004
my Bullitt has a strange and annoying squeek coming from the dash as well. Haven't figured it out yet though. Also have yet to establish a pattern as to when it squeeks.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 5, 2004
  • Jan 5, 2004
I got the same exact problem and can't figure out what's causing it. It makes noise randomly too not at certain times.
Premium Speed
1,006
Houston, Texas
Jan 5, 2004
  • Jan 5, 2004
"The "chirping " noise is the cowl outside under the wipers, I fixed mine.
Just remove the wipers, remove the screws holding the cowl in under the hood, and the pull up on the cowl. Be careful though, because the washer lines are attached. You will then see how the cowl is attached to these clips. I put electrical tape on the cowl portion of the clips and pushed them back in.
No more sqeaking! Reverse assembly."
this wasn't written by me but it worked for my car. it may or may NOT work for you. some mustangs have a squeak that comes from behind the instrument cluster, that i have no idea how to fix.
GoBabyVroommm
1,156
Chicago, For Realss???!!!
Jan 5, 2004
  • Jan 5, 2004
I have that problem too. In time every mustang does that. Its because being cheap on the parts.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 5, 2004
  • Jan 5, 2004
Thanks alot Premium Speed, ill give it a try.
stangman
2,690
10
69
in a 3 bed, 2 bath
Jan 5, 2004
  • Jan 5, 2004
i have the same squeek in the dash of my 03 & i ended up putting a nickel in the space between the vent & the dash i know it's ghetto, but it worked my car is at ford right now for a busted tranny & i forgot to mention that to them, but i'll do that after i hear that it's drivable
brando
28
Alabama
Jan 5, 2004
  • Jan 5, 2004
Hey Premium, thanks a ton for that info. I just went out and looked under the hood. I lifted the weather striping and am missing the three fastener clips. All three. I found out about this a little while ago on IMBOC.com too.
i can't wait to get under the hood and fix this.
Thanks again...you're the best.
C
claytucc3
825
Santa Clarita, Ca
Jan 5, 2004
  • Jan 5, 2004
I use the CFOD method and it usualy goes away...lol
C-closed
F-fist
O-on
D-dash
forpit2000gt
2,490
Columbia, SC
Jan 5, 2004
#10
  • Jan 5, 2004
  • #10
my squeeking came from the cluster. it was the plastic tabs that are on the back of the benzel. a little silicon fixed it.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 5, 2004
#11
  • Jan 5, 2004
  • #11
Crap,lol. I have that problem, too. I have every squeaking, rattling, and shaking noise possible in a Mustang. I have the cluster, dash, and middle instrument panel noises. I need some subframe connecters and a strut tower brace to reduce this stuff.
- Did you just unscrew the 2 screws at the top of the cluster and pull back?
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 10, 2004
#12
  • Jan 10, 2004
  • #12
Bump
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
