DD help! not my stang
  • Thread starter Thread starter Foxfan88
  • Start date Start date Nov 9, 2006
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Nov 9, 2006
  • Nov 9, 2006
ok my dd is a 95 s-10, 4.3 with a 5 speed.
truck runs great most of the time
a while back i got a check engine light on the interstate. for about a min or 2 and it went off.
since then my truck may die upon start up every once in a while. not every time. maybe 1 in 5 times.
it will start and surge and die.
i had the codes scanned and nothing came up
then today i was sitting for a while and i started the truck. the engine surged REAL LOW like it was loading up and i smelt fuel.
then it smoothed out after a min or 2
i was pressing the gas alot while the truck was off so i thought maybe that did it. since its TBI but it didnt seem right.
truck ran smooth. then it sat again for an hour and then i did it again. surged and smelled fuel it was idling real low and shaking like it wanted to die
then smoothed out after a min and then drove flawlessly home.
its been sitting for 2 hours and i just started it up. ran fine... started right up and idled perfect!
only thing i ahve done is put a bottle of fuel injector cleaner in but i highly doubt that has anything to do with it.
any ideas?
rickd93_lx
162
  • Nov 9, 2006
fuel filter maybe? id give that a try, sumilar situation happened to a 2.3 stang i had i changed the fuel filter and everything was fine after that. just a thought, and a cheap one at that.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Nov 9, 2006
  • Nov 9, 2006
fuel filter was changed bout a month ago
sunil6784
620
Boston, MA
Nov 9, 2006
  • Nov 9, 2006
Check engine light came on, but no codes were present? Did the guy check the memory too ? KOEO and KOER ?
stangjunkie
381
  • Nov 9, 2006
probably not... if you go to someone like advance or somebody to do a free one (free scan) then they only check it if the light is currently on most use and actron cp9145 which wont check stored codes, only active codes.
sunil6784
620
Boston, MA
Nov 9, 2006
  • Nov 9, 2006
EGR problem ? that can sometimes be a stored code... i think
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Nov 9, 2006
  • Nov 9, 2006
i go to a tech school and i used to go the automotive class. i took it to them and he checked all that stuff.
z2o_what
309
princeton, WV
Nov 10, 2006
  • Nov 10, 2006
my s10 used to do that, then the fuel pump went out (not sure if the two problems were related) but after i changed the pump it has ran fine. i still smell gas from time to time though.
btw if you ever have to change the pump remove the bed, i spent 3 hours tring to get the tank out, and said f it and removed the bed (30min).
sell the truck while its running... fuel pumps are expensive for them things.
but... it mitght not be the pump and you wouldn't want to sell your truck because some guy on the internet told you to, right?
HISSIN50
34
129
Nov 10, 2006
  • Nov 10, 2006
I did the pump in a 92 S-10 (4.3L) and the bed removal sentiments are about right. It was a pain to drop the tank (it was a full tank though). A Delphi pump was not expensive though.
If yours is the same induction set-up, it only uses about 14 PSI - a slight lack of pressure really makes a difference.
When I diagnosed the pump, I farted around with it idling and after run-time, the diaphram in the pump was getting hot and weak and it would start running rougher. Eventually, it would stall and no longer catch upon restarting (don't drive it far from home is the point).
Good luck.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
