Dealer Decals
  • Thread starter Thread starter 05GTDavid
  • Start date Start date Jun 12, 2015
05GTDavid
  • Jun 12, 2015
What is the best / safest way to remove those dealer name deals from car with no damage ??
05GTDavid
  • Jun 12, 2015
I know - search button first ! duh - my age showing again !
chgovfk
531
28
59
AZ
Jun 17, 2015
  • Jun 17, 2015
The best way is to simply try - with a finger nail to grab an edge and peel - depending on the 'age' of the decal, once that is done adhesive remover and then some rubbing compound, there
'may' be a shadow of the decal on your paint - hard to describe, you can see it only in certain deflection of the sun, if its a nasty decal - light passes with a heat gun and or blow dryer to loosen the decal, but be careful w/the heat .....standard 8" to 6" away - invoke some patience, many passes, you can melt the paint.
Paul G
106
11
29
Jun 19, 2015
  • Jun 19, 2015
For getting the decal off, as suggested above, but you may also check with a local body shop or a shop that specializes in wraps and wrap removal.
After you get the decals off, it may be a good time to do a thorough wash (by hand), clay and then either use an AIO such as HD Speed, or a mult-step process cut / polish & wax with a dual action machine. Remove all polishes and waxes by hand with soft plush microfiber.
This will a.) remove any swirls, RIDS and scratches that already exist and two, level out the areas where the decals/stripes were and you'll have a consistent looking glossy car.
Reactions: 1987stangman
N
nbk13nw
186
Newport News, Va
Jun 19, 2015
  • Jun 19, 2015
I was able to use floss and saw it back and forth to remove the dealer badging. For decals I used a heat gun and finger nail with no damage
D
Dealer installed a/c
  • doug.smith1409
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
General karthief
F
1985 GT Hood decal recommendation
  • frwgt350net
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 12, 2026
frwgt350net
F
I
2023 mustang gt fastback help
  • Izhar8709
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
LILCBRA
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 1:33 PM
Don7Up
D
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
