Decodiing rear-end tag
chepsk8
2,203
Easton, PA
Trying to see what gears are in the diff.
I know that in the old rears, the group of numbers in the lower left corner described the ratio, ring gear size, and posi/non-posi. Is there any similarity with the tags on the 8.8? My car has the tag still on it, and am hoping to be able to read it.
thanks!
i don't know about that, but you can throw the rear end up on jack stands and have someone rotate a wheel around one full turn, mark the driveshaft and count the rotations....however many times around is the gears you have....just under 3 full times is 2.73's, just over is 3.08's most likely, etc That's what I did.
