Degreeing my cam ?
  • Thread starter Thread starter TrickFlow
  • Start date Start date Aug 22, 2005
TrickFlow
340
Bossier City, La
Aug 22, 2005
  • Aug 22, 2005
Im takin the motor this week to be taken apart, clearances checked, balanced, and having the cam, and heads installed (i dont know enough to degree the cam myself, and my torque wrench is MIA) What im trying to figure out is what degree should i request the cam to be set at... is this a manufacturers recomendation, or does it depend on motor setup.....? any help would be greatly appreciated.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Aug 22, 2005
  • Aug 22, 2005
When you degree the cam you are just verifying the valve events compared to the advertised specs and then making slight adjustments accordingly.
Most of the time people install the cam straight up. You can go up to 4 degrees advanced / retarded. I don't remember correctly but if you advance you get a little more HP and lose some Torque and then if you retard you get some more torque and lose some HP...
To degree the cam you need a degree wheel, dial indicator with magnetic base and your cam spec card. I think Comp cams has a good write up on their site about it also.
TrickFlow
340
Bossier City, La
Aug 22, 2005
  • Aug 22, 2005
Thanks for the info... im takin it to the machine shop as i said, and they had told me to know where i want the cam (advanced/retarded/straight) when i bring it up there, so i thought id just check to make sure.. everyone else ive asked said to just install it straight up as well.
Rick 91GT
Mustang Master
95
99
PA
Aug 22, 2005
  • Aug 22, 2005
What's the combo, what cam?
TrickFlow
340
Bossier City, La
Aug 22, 2005
  • Aug 22, 2005
-Block Bored and honed to 306
-Trickflow 10:1 forged pistons
(all being balanced this week)
-Trickflow Track Heat Heads
-RPM Air Gap intake
-Holley 600cfm double pumper
-Trickflow 6.700 pushrods
-Trickflow stage II cam ( duration 224*/232* lift .542"/.563")
-FMS lifters
-BBK Shorties
-H pipe
-Stock gears for now (308)
-Rebuilt T-5 with hanlon block & ring kit
-Super King Cobra Clutch
CManT1914
3,172
Killeen, Texas
Aug 22, 2005
  • Aug 22, 2005
Retarding the cam moves the powerband lower.
Advancing the cam moves the powerband higher.
It just depends on where you want your power as opposed to where the cam makes it's power normally. For instance, if your cam makes peak power at 5,500 rpm degreed straightup, and you want your power a little higher, then advance it some.
TrickFlow
340
Bossier City, La
Aug 22, 2005
  • Aug 22, 2005
Edit, i forgot the Scorpion 1.6 rockers... they should be here tomorrow
TrickFlow
340
Bossier City, La
Aug 22, 2005
  • Aug 22, 2005
dont forget about me Rick w00t!
Rick 91GT
Mustang Master
95
99
PA
Aug 22, 2005
  • Aug 22, 2005
I'd install that straight up to begin with.....
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
