Deleted egr and smog what vac lines to block?
Honestly there are alll sorts of things you can remove with the EGR and Smog delete. I took the front passenger fender off and took out the smog solenoids and charcoal canister. With that you will be completely removing the red, green and off white colored vacuum lines, along with the vacuum line that runs off the intake to the charcoal canister with the solenoid off the firewall. I guess it just depends on how much work you want to put into it. If you just want to plug things, plug the red, green, and whitish colored one that was down by the pump.
Edit: If you remove the charcoal canister, you have to follow the vent line back to the gas tank and unhook it so it can vent out under the car in the rear. Otherwise, if you just unhook at the canister by the front passenger door, you will have gas vapor smell in your car!
