  • 1994 - 1995 Specific Tech
Deleting PCV? Should I do it?
  • Thread starter Thread starter BlueOvalStangGT
  • Start date Start date Nov 26, 2005
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Nov 26, 2005
  • Nov 26, 2005
I run a breather on my valve cover but I still have my PCV hooked up. I think the PCV valve has something to do with the oil I found in intake manifold so I figured I would delete it. Cant I just keep the breather on the valve cover and put another breather on hte back of the lower intake? That would work the same right?
rgs
124
Vancouver, Canada
Nov 26, 2005
  • Nov 26, 2005
rig up an oil seperator in the pcv line
HISSIN50
34
129
Nov 26, 2005
  • Nov 26, 2005
Whatever you choose, running a breather and PCV is kinda of a mixed bag of poo. I would go one way or the other. Simply stated, the breather set up will not actively scavenge vapors from the crankcase like PCV does. On a forced induction set-up, things change. Often times, a light-bar set up can get away with a forced induction PCV valve. Or guys just run all breathers and delete the PCV.
Tim has some very nice write-ups on crankcase ventillation dynamics - he says it much more eloquently than I.
Good luck.
BlueOvalStangGT
2,849
Nov 27, 2005
  • Nov 27, 2005
Is it really that neccesary to have?
HISSIN50
34
129
Nov 27, 2005
  • Nov 27, 2005
Is the PCV really necessary? Not especially (though few alternatives are as efficient). But you do need to ensure you have adequate bi-directional ventillation of some sort.
Good luck.
BlueOvalStangGT
2,849
Nov 27, 2005
  • Nov 27, 2005
Would filters on both ends be enough? I actually just put a filter on the end of the pcv valve and a filter on the valve cover.
18mustangs
533
Virginia Beach, VA
Dec 2, 2005
  • Dec 2, 2005
No filtered breathers alone are not enough as you are equalizing the pressure between the crankcase but you're not evacuating the crankcase of the corrosive vapors like the PCV system does. The stock PCV system when properly maintained is a good piece of engineering and costs you zero performance and extends engine life. Just keep it and drive on. :SNSign:
Tim
OrangeMustangGt
1,976
Cape Cod, MA
Dec 2, 2005
  • Dec 2, 2005
i agree,,,,who wants oil blowing out into your hvac vents?
BlueOvalStangGT
2,849
Dec 2, 2005
  • Dec 2, 2005
Well, how am I supposed to run it then?
a50sn95
368
Elk Grove, CA
Dec 2, 2005
#10
  • Dec 2, 2005
  • #10
I run mine just like stock, with a separator, and a turbo coupe PCV valve.
And I don't think the seperator does any good on my setup. (Fresh short block, good ring seal...)
Dennis
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Dec 3, 2005
#11
  • Dec 3, 2005
  • #11
i deleted the pcv when i switched intakes. i have both valve covers breathed. we will see how it works out as soon as i have the car completely together again.
OrangeMustangGt
1,976
Cape Cod, MA
Dec 3, 2005
#12
  • Dec 3, 2005
  • #12
what i did was sorta wierd, but it works. Since i used my origional PCV location as my oil dump for my turbos, i ran the pcv hose from the upper intake, through a brake booster check valve to the pass. valve cover where the nipple is on the fill neck. Then i put a breather on the oil fill cap. its crazy, but it works damn good.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
