Vehicle: Stock 89 Mustang GT, about 150,000 miles.
Problem: With less than half tank of gas, 'Stang will feel like it won't take the gas during a turn. You can push accelerator and no increase in power. Slight and slow drop of rpm, not sudden. Then, all will be fine and it will accelerate. Occasionally it will even stall.
What's been done:
Cleaned EGR, IAC, throttle and MAF sensor and connectors.
New rebuilt distributor with new ignition module, cleaned connectors
New fuel pump and cleaned connectors.
New cap, rotor and Ford racing wires.
New EGR position sensor.
New fuel filter.
Checked for water in gas and ran a bottle of dryer through.
Measured fuel pressure, is in spec for idle but almost 5 psi low with key on engine off as the shop manual says this should be 5 psi higher than at idle.
Checked fuel pressure regulator for leaks, none.
Cleaned the "salt/pepper" connectors.
Visually inspected for vacuum leaks.
Checked the TPS with digital at both extremes and analog throughout the sweep with no drop outs.
Checked throttle cable for binding.
Checked fuel pump relay, harnesses and inertia switch by wiggle-test, all OK.
Wiggle-tested fuel pump harness on top of fuel tank.
Pressed the inertia switch button just to be sure.
Codes set: 67 (Neutral safety circuit failure)with 95 (Fuel pump secondary circuit failure when the PCM commanded the fuel pump on, voltage was not detected on FPM) in continuous memory. Don't know why 67 is set unless the un-used switch I found when I put in the new 93-spec'd T5 transmission has something to do with it.
I'm just about to sell the POS if it can't be fixed! I've been messing with this most of this year. I've never had a car beat me but this one has me and all my buddies at a loss. Please, give me some ideas of what to check. I plan on troubleshooting the 95 code (Fuel pump secondary circuit) in full this weekend.
The 89 Mustang used to be the most reliable car we owned. It's in nearly perfect condition and would really hate to roll it over a cliff. It has about 150,000 miles.
PLEASE HELP!
Mikey
What's been done:
New fuel filter.
PLEASE HELP!
Mikey
