  • 1994 - 1995 Specific Tech
Detailing the engine bay?
  • Thread starter Thread starter xYoung347x
  • Start date Start date May 28, 2004
xYoung347x
382
  • May 28, 2004
Since I have finish putting in my 347 stroker motor and all the stuff I took off. (egr, a/c, ect.) I want to fill in the little holes that is everywhere in the engine bay. How can I do this at home with some tools instead of taking it to a shop? Is there a website on how to do this step by step and all of the equipments that are needed? Thanks
OinkAodeOink
3,026
Daytona bch, Florida
May 28, 2004
  • May 28, 2004
depends how far you want to go with it..
You could go an easy simple route without any body work involved. Go buy some of those large headed push in fastners ( like the one holding your door panel on)
Buy a bag of those, and paint em all your engine bay color, once dry push em in the empty holes.. Worked for my car and looked nice.
Otherwise, your going to have to get out some body filler, or start welding the holes shut, then body filler to smooth em out, then paint it all.
xYoung347x
382
  • May 28, 2004
what about the holes that are oddly shape? What about the bigger hole ones?
oink can you hook me up with some close up pix of your engine?
ShiftTheDrift
365
Bakersfield, CA
May 28, 2004
  • May 28, 2004
Damn, that's a really good idea! I was wondering about this a couple weeks ago. Smart man.
xYoung347x
382
  • May 28, 2004
TTT
OinkAodeOink
3,026
May 29, 2004
  • May 29, 2004
i also used rubber fuel hose, slit it down the middle and wrapped it around the sharp edges of these cutouts.. Theres really no way around it, they will be there unless you cut out sheet metal and weld fill in plates on, then bondo it all smooth. Or cut out sheet aluminium to the holes size, then rivit it in place ( would look cheap though)
OinkAodeOink
3,026
May 29, 2004
  • May 29, 2004
pics...
xYoung347x
382
  • May 29, 2004
Oink, where did you get those things that cover the big hole by the CC plates?
xYoung347x
382
  • May 29, 2004
P.S. Oink, I dont know if you know this but, page 3 on "wire hiding 101" its a dead link.
stylin97v6
#10
  • May 29, 2004
  • #10
weld, bondo, paint is about the only way to do it perfectly..
heres some pics of what i did. Mine didnt turn out perfect (im a n00b welder) but it looks alot better than before. I still really want to cover the frame rail part flat (where the bottom of the CAI would go) but that will happen later.
before..
during..
after..
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
