Detonation "101".....
  • Thread starter Thread starter atey950
  • Start date Start date Dec 18, 2003
atey950
516
60
59
Southeastern PA
Dec 18, 2003
  • Dec 18, 2003
Can someone please teach me what detonation is?
I just got a car equipped with the mods in my sig. I want to know
what is it?
when does it occur?
what harm can it cause?
what is done to prevent it?
Thanks.
C
cmclean
243
Houston, TX
Dec 18, 2003
  • Dec 18, 2003
One cause of detonation is advancing the timing too much, or running too few of octane rating in your gasoline. Either retard your timing or run higher octane gasoline.
DavidF
158
Ventura, Ca
Dec 18, 2003
  • Dec 18, 2003
Detonation occurs when part of the a/f mixture ignites on its own then the spark plug ignites the rest of the mixture then the two flame paths collide causing a violent ping. You also have pre-ignition; That’s when you have a “hot” spot in the combustion chamber ( like a sharp part of the piston) that heats up and causes the a/f mixture to ignite. Giving the same result as detonation.
HISSIN50
34
129
Dec 18, 2003
  • Dec 18, 2003
sounds good. it's a snowball thing too, as the detonation or pre ignition cause temps to skyrocket, and this causes more preignition or detonation. other causes of preignition are carbon deposits in the chambers. carbon deposits can also raise compression ratios, exasperating problems.
just listen for pinging and if you hear some, try either backing timing out or higher octane fuel, whichever is most pratical (usually timing). i back timing off a degree or two in the summer (110* here) to help ward it off.
you are right to ask the question, as detonation/preignition of any kind is horrible and extremely stressful on your motor.
David, i have wondered this, and you touched upon it: i kinda thought that the pinging noise was caused by the piston being slapped around in the chamber (frequencies of violent shockwaves from the two explosions, squish area flaming, etc). am i just wrong, partially wrong, or is it really from the two flame fronts colliding? (not trying to be a jerk, just want to learn). thanks.
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Jul 22, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
