Detonation
  • Thread starter Thread starter Paul Perreca
  • Start date Start date Dec 12, 2005
1 of 2 Next Last
Paul Perreca
1,085
  • Dec 12, 2005
My car is running really lean, found out when we changed the spark plugs yesterday - today, i kept the windows up n gunned it, and heard some "pinging" maybe detonation, can running too lean cause detonation? I would think so - but not sure, and how can i adjust the fuel pressure w/o a guage to up it - i have an adjustable fuel pressure regulator - and get this, 5.0 magazine has an article that says you don't plug the vac line when you take it off, leave it open to the atmosphere and you will lose approx 4-5 lbs pressure at WOT or something of the sort -
THANKS
Paul Perreca
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 12, 2005
  • Dec 12, 2005
THANKS
Paul Perreca
that doesnt even make sense , the reason you pull the vacuum is to get a WOT reading so pluging the vacuum hose does nothing to change the setting ....it only helps keep the car running smoothly while you are adjusting things ......when you unhook the vacuum from the regulator you have 0 inches of vacuum , just as if it were at WOT so how would plugging it or not plugging the vacuum affect anything to do with the regulator .... you need to go by a fuel pressure tester from a local parts store ....they cost about 35-40 bucks and are well worth the money ....
Paul Perreca
1,085
  • Dec 12, 2005
yea i dont know how that makes sense lol I just read it - but neway, do you think that is my detonation problem? the leanness?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 12, 2005
  • Dec 12, 2005
what plugs you running and what is your timing at ?
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Paul, running lean can definately lead to detonation.
I read that same blurb IIRC and the difference was that they simply choose not to plug the vac line when they remove it. Removing the line simulates WOT (zero manifold vac) and the pressure does go up by 4-8 PSI.
Now they simply have a slight vac leak goin on by not plugging the line. This theoretically raises the idle a hair, which leads to a tiny difference in the setting compared to how most of us recommend setting it. It is not worth worrying about at all IMHO.
You really should get a gauge of some sort so you can see what is going on. I am not one for permanent under the hood FP gauges, so I just use the diagnostic gauge when needed.
Good luck.
Paul Perreca
1,085
  • Dec 12, 2005
plugs installed yesterday were the autolite 3924's requested by 99% of everyone on here that replied to me w/ aluminum heads - so i listened and got them - timing has never been set - no idea
HISSIN50
34
129
Dec 12, 2005
  • Dec 12, 2005
Paul, you gotta check that timing. Too much advance can lead to detonation as well.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 12, 2005
  • Dec 12, 2005
timings the problem , that and probably dont have enough fuel pressure in it ...but timing will affect it above all else
Paul Perreca
1,085
  • Dec 12, 2005
yea i never even checked it cuz when i put the light on it to check it, the numbers on the balancer were painted black and i couldn't read them -
than we had to do somethin else n never got back to it
Curse
791
El Paso, TX
Dec 12, 2005
#10
  • Dec 12, 2005
  • #10
Get timing tape, it will make reading the timing a lot easier. Also get a reading on your fuel pressure. Some AFPR are not set right out of the box, so who knows what your FP is set at.
Black1987Stang
1,422
Jersey Shore
Dec 12, 2005
#11
  • Dec 12, 2005
  • #11
Go check that right now lol Dont want to ruin that nice new motor you got there I have an excuse about mine, since mine says 65 degrees advanced Ive been tuning the timing by ear which isnt exactly the best but cant find out my problem ever since i put my new motor in soo its gonna have to stay like that till i find out whats wrong
Paul Perreca
1,085
#12
  • Dec 12, 2005
  • #12
yea i guess we kinda timed it by ear, so it's not gonna hurt, just might not be getting all the performance out of it, or it could be off enough to cause the DET
HISSIN50
34
129
Dec 13, 2005
#13
  • Dec 13, 2005
  • #13
Paul, man you gotta clean your ears. The whole point of 'timing it by ear' (which we all do) is to back it off if pinging is heard.
sgarlic
3,085
Dec 13, 2005
#14
  • Dec 13, 2005
  • #14
Maybe your car is like mine was.. detonated at anything over 9*
Just borrow a timing light from somebody.. it's simple.. use chalk.. just check it!
Black1987Stang
1,422
Jersey Shore
Dec 13, 2005
#15
  • Dec 13, 2005
  • #15
White out works even better
HISSIN50
34
129
Dec 13, 2005
#16
  • Dec 13, 2005
  • #16
I use a silver sharpie marker on black balancers. Seems to hold up well.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Dec 13, 2005
#17
  • Dec 13, 2005
  • #17
Paul I'd follow JT's advice..get a timing light on there pronto!..detonation is really NOT good for the engine and it's something you want to take care of early. Remember when you asked me what was on the cowl of my hood...well that was a fuel pressure gauge, it may not look pretty sitting up there, but it's a tuning tool for me and IMO you need on somewhere on that car. When running a modified car like you are you need to "fine tune" some things inorder to keep it running correctly and safely for the motor...GET ER DONE.
Paul Perreca
1,085
#18
  • Dec 13, 2005
  • #18
i can't just back it off by ear cuz it only detonates when at full throttle.... so i will just not floor it till i figure this out
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Dec 13, 2005
#19
  • Dec 13, 2005
  • #19
My father refers to such methods as half assed...I suggest you take 5 minutes and do it right, nothing but good will come of putting a timing light on there.
Black1987Stang
1,422
Jersey Shore
Dec 13, 2005
#20
  • Dec 13, 2005
  • #20
Yea and theyre like what 20-30 bucks from autozone or something? Its well worth it anyways
1 of 2 Next Last
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
