Detonation?
  • Thread starter Thread starter z9_87
  • Start date Start date Apr 7, 2006
z9_87
332
Urbana, IL
Apr 7, 2006
  • Apr 7, 2006
I have a new little gremlin that poped it's head up recently.
When under high-load low rpm acceleration or durring deceleration from higher speeds(55+) it seams like I get detonation. It makes a usual noise of detonation and tries to go but just sits there and sputters if I hold it there. If I step on it while its sputtering, it intstantly goes away.
So detonation check list that I can think of:
timing - 10*
fuel - 90
compression is around stock for a 89-93
lean mixture maybe? - it's 19lb injectors no egr.
I don't know beyond that anyone have some suggesitons?
HISSIN50
34
129
Apr 7, 2006
  • Apr 7, 2006
Zach, is this mostly while in OD?
Also, if you happen to know (I'm not familiar with the changes for 'Birds), is the puter RPM or load based? Electronic or mechanical trans (I assume RPM based and mech trans, but wanted to ask).
Good luck.
z9_87
332
Urbana, IL
Apr 8, 2006
  • Apr 8, 2006
Actually the OD went out on my tranny, thats another problem but i know what to do with that. The tranny is an AOD just like in the foxes and the computer is an 89 stang mass-air.
It pretty much never happens in 1st cause of the higher rpm's. But 2nd and 3rd when low rpm accelrating it happens a lot.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 8, 2006
  • Apr 8, 2006
my truck makes the same type of noise and it is just a very small exhaust leak. It makes the noise only under load accelrating but goes away when there isn't much of a load.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 8, 2006
  • Apr 8, 2006
for right now you could just try some higher octane. It may be carbon buildup on the top of your pistons giving you higher compression. wouldn't hurt to try running a can of seafoam through a vac line but try some higher octane first.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2006
  • Apr 8, 2006
i was going to say it could be carbon build up. they cause hot spots which ignites the air fuel mixture prematurly. need to clean up the combustion area.
Hickfied
413
Morganton, NC
Apr 8, 2006
  • Apr 8, 2006
You don't have the EGR system hooked up do you? I think that is your problem right there, though I could be wrong.
z9_87
332
Urbana, IL
Apr 9, 2006
  • Apr 9, 2006
No I don't have the egr, and I was wondering about that. I have already tried some 93 for a tank.
I'll run a can of seafoam through just to see if that does anything.
And the header bolts wiggle loose every now and then so I guess I can take awrench to them, but I know there's no rust or anything like that on em.
Thanks for the replies.
vristang
4,933
101
124
Seattle
Apr 9, 2006
  • Apr 9, 2006
If the egr is tha cause then you will need to reinstall the egr or disable the function of the egr in the computer.
Mine pinged pretty bad until I started playing with the tweecer. Now my ping is all but gone.
jason
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Fuel Spits sputter pops and bangs under load. Help wanted
  • sickntired
  • Mar 23, 2024
4K
Fox 5.0 Mustang Tech Apr 1, 2024
sickntired
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
Odd Noise?
  • Sn97azgt
  • Feb 27, 2018
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 28, 2018
General karthief
