detonation???
87muscle
11
i got a 87 mustang gt,i got a few mods but nothing major, and i seem to have a detonation problem that i cant figure out.
the car runs great till i get on the highway, doing about 65 and when i floor it it starts to detonate.
the sound it makes is hard to describe but it kinda sounds like a rattle snake
if i run 93octane with octane boost i dont get the noise.
one more thing, every time im driving down a bumpy road my car sounds like a train on train tracks and the noise seems to be coming from around the passanger front tire area
please help!!!
thanks in advance
Trace the dizzy harness from the TFI (the harness you probably unplugged). After tracing about 6" or so, you'll see two wires that stray out of the harness and go to a connector with a grey plastic 'chip' in the end. Unplug the chip (SPOUT connector).
Good luck.
i got the timing set at 10 degrees with the spout disconnected.
modifications: 3:73 gears, 255 lph, accufab fuel regulator, b & m pro stick shifter, b & m shift kit, bbk off road h pipe, bbk shorty headers, underdrive pullys, 70 mm bbk throttle body, k & n air intake, camshaft
In addition to checking the timing you might want to go through the car and give it an overall tune up, depending on when the last time that it was tuned up. Plugs, wires, cap rotor, air filter, fuel filter and the like.
Also pull codes to see if you might be having a problem with the EGR valve that might be preventing it from working properly. A non functioning EGR can cause detonation.
