diablo predator question
loosescrew79
313
I just installed my o/r x pipe. The car sounds awsome. What do I need to do with my tune now. There is a setting on the tuner for O2's. do I turn them off or use the MIL setting. I'm not sure so I figured I'd ask the pro's.
I do not have an engine light problem yet. The stock O2s (all 4) plugged back into the x pipe.
If you have the tuner, you don't need MIL eliminators. Just use the tuner to turn the rear sensors OFF. Enjoy :nice:
As far as power wise you'd need to put it on the rollers with an A/F Sensor to see if you need to add fuel or whatever.
You allready got your answers on the MILs to turn off.
loosescrew79 said:
The tuner has two options - one is to turn off the o2s and one is for the MILs. I need to just turn off the 02s only, right.
Right, but you will still need to get it on the rollers with an A/F Sensor to see if you need to add fuel or whatever.
If I have this right:
Mil eliminators installed on an o/r pipe will tell the computer all is well. All you need to do is tell the Predator that they are installed by selecting "Mil". I guess it is set up like this for those who bought the MILs first (cheaper) and then the tuner.
Diablo tells the computer all is well by disabling the rear O2s all together.
On mine there is like 3 different things to turn off. I forget exactly what they are but you want to turn off all of them.
As far as a/f I didnt adjust mine at all and I am running max timing.
propellerhead said:
I can't remember off the top of my head but the Predator manual covers what you should turn off. If not, the FAQs on the Predator website lists what you have to do.
They do, I'm just not reading em for some one elses benefit that can do so just as easily as making a new thread ;)
Alright I will turn the o2s and not mess with the MIL setting.
I need to call me mobil dyno buddy and give my cars a couple of runs to tune the a/f mix.
thanks alot guys
