DiabloSport Predator
coldstaindtears
110
New Jersey
I just installed the Performance Tune on my DiabloSport Predator for my 2003 Auto. V6, and damn its awsome. I feel some more power at my disposal, and my tires are chirping when at WOT going into second. I've gunned my car plenty of times and thats never happened. I'm probably not going to see any increase in MPG cause I've been gunning it left and right here. Haha.
Our cars are equipped with sensor that monitors detonation, right? I was really kinda nervous about installing the tune before hand and I just dont want to hurt my car in anyway.
Sweeeeeeet.
If I change the shift pressure firmer does that increase the chance of failure in the future? Some people have told me that it extends the life of the transmission when you have quicker firmer shifts, but other people have said the opposite.
Niterydr85 said:
Do you have any other mods or are you still stock beside the tune??
I have a eBay Cold Air Intake and a Borla Side Exit Exhuast already on the car. I also have in my possession waiting to be put on; Underdrive Pulleys and a 1/2 Shafted Ported/Polished Throttlebody.
-Also-
Since most people recommend that when put a new mod on your car that you unplug the battery to reset the computer, shoud I uninstall the Diablo tune, reinstall the factory tune, unplug the battery, and then reinstall the Diablo tune, or is this unnecessary?
What is the safest I could possibly extend the rev limiters for my car for each gear? I've seen people put 1st gear up to 6250, and so (probably not the best idea) Should I waste my time or should I just leave it at stock?
Also, 'Torque Modulation', I read the manual and I'm not really sure what is really does and if it is worth messing with? Anyone have any experience with that?
I don't personally use a Predator with an automatic transmission but others have posted they liked the results of turning the torque modulation "off". I left the rev and speed limiter at the stock setting on my car.
Here is an explanation of TQ modulation from another site I am a member of:
Torque modulation is the amount of timing retard at WOT shifts. I tried both, if torque modulation is left on or "0", the timing will retard to about 10 degrees when shifting. You can feel this. If set off, or "100" 100% of timing will remain when the trans shifts. In this setting, the car pulls right through the rpm range when shifting between gears. The shift pressure merely adjust firmness or how hard you want the transmission to shift.
