diagnostic problems
88mustang92
105
i wanna read codes that my computer is throwing out, but i have one problem, the diagnostic connector has only 1 wire connected 2 it, there is anoth wire haning by it but i dont think it would be useful b/c it looks corroded.... Also i have all the egr stuff disconnect, wiring, vac lines, cats, smog pump, everything. Another small ? Is there a problem with doing this? Also i have the edelbrock performer rpm intake, and there are 2 smaller vac lines on the back of it, one goes to the BAP and the other goes to the FPR? Is this right or not?
If you have a MAF conversion, the BAP doesnt get connected to manifold vacuum.
Dont accidentally connect your underhood light (a 12 volt source) to the data connector. Hood light connectors are often black.
alright the about the bap, it has a nub coming off the end of it along with an elec connector with it, so would i just plug this off? btw what are the 2 vac ports for exactly, one is bigger than the other,
u will have to excuse me hissin, i do have a map sensor not a bap sensor, n that is plugged into one of the smaller vac ports on the intake, the other is run to the fpr (fuel pressure reg) does that seem correct?
A MAP and BAP are essentially the same thing. The only thing that differs is how it is used for the application. If you have a MAF sensor, you vent the BAP/MAP to atmosphere. If you are Speed Density, the BAP is connected to a manifold vacuum source.
You dont want to have a BAP/MAP connected to a vacuum source if you have a MAF car.
Ok i do have a maf conversion 4 sure, sorry bout that mix up of the map/bap thing, so what should the 2 vac ports on the back of the intake be for? sorry so many ?'s im very new 2 this!
I don't run that intake so I can't say. You don't have much on the car anymore that requires accessory vacuum however. You might end up capping one or both ports.
