Did I hurt anything?
  • Thread starter Thread starter 68stang351
  • Start date Start date Jan 27, 2004
68stang351
850
9
39
Savoy TX
Jan 27, 2004
  • Jan 27, 2004
My car is making a "tick tick tick", so during investigation of the header bolts I noticed that two of my plug wires were not slipped all the way onto the plugs. By the way they were on there, it would seem they wouldn't fire. But the car felt like it had plenty of power and was running good. I've been driving it hard and racing with it like that and I wondered if it hurt anything. I'm not sure how long its been that way either.
kslushy
1,125
Jan 27, 2004
  • Jan 27, 2004
Dont worry about it. Its never really a good thing persay, however even if you were running on 6 cylinders, its not going to destroy your motor or anything.
68stang351
850
9
39
Savoy TX
Jan 27, 2004
  • Jan 27, 2004
I didn't think so, but when it comes to my baby, I get paranoid.
raczg
37
Phoenix, AZ
Jan 27, 2004
  • Jan 27, 2004
You should pull those plugs and see what they look like. They might have gotten a lot of build up on them. Clean them and put them back in.
6Stang7
1,470
Livermore, CA
Jan 27, 2004
  • Jan 27, 2004
The noise was most likely the spark jumping the gap between the plug and wire. The noise did go away though? If not, then you have a more serious problem here with your valve train.
-Shaun
NoKitten
189
Room 117
Jan 27, 2004
  • Jan 27, 2004
Never be afraid to be paranoid....
(what was that?!)
~Meow
68stang351
850
9
39
Savoy TX
Jan 27, 2004
  • Jan 27, 2004
-Shaun
Yes, it quit, but I also tightened a couple of header bolts, so I'm sure if it was the bolts being loose or the spark jumping that was making the noise.
R
rmrfstar
31
Chico, CA
Jan 27, 2004
  • Jan 27, 2004
Spark plugs will fire if the plug wires are not touching as long as the electricity can bridge the gap. If the spark is jumping twice(wire to plug and on plug), there will be greatly reduced spark power.
G
GaPonyFarm
663
Columbus, GA
Jan 27, 2004
  • Jan 27, 2004
Your noise was most likely an exhaust leak, if it was otherwise running good. You would have noticed 2 cylinders not firing. You might want to check your exhaust manifold gasket and add some Stage 8 locking header bolts.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
