Did my mechanic screw me?
  • Thread starter Thread starter El Horsepower
  • Start date Start date Feb 16, 2008
E
El Horsepower
15
  • Feb 16, 2008
I recently had a mechanic get rid of header bolts that had broken off and rebolt my header back on. When I got home, I noticed if I turned my steering wheel all the way either way while moving, there was thumping noise and the car repeatedly bumped with each thump. The sound always comes from the engine bay area in front of me. Could he have screwed something up? I put new wheels on as well but they were the same size as my old ones and they are low profile tires so I don't think they are rubbing. Help is appreciated!
E
El Horsepower
15
  • Feb 16, 2008
mispost
sn-95matt5-0
170
  • Feb 16, 2008
what is the offset of the new wheels it sounds like your wheels are rubbing in the inner wheel liner. mine does that with my 275 tires on my stock 00 gt wheels
. next time you get a chance look and you should be able to tell by the scrape marks.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Feb 16, 2008
  • Feb 16, 2008
Two guesses:
- New wheels
- Steering shaft is hitting something
Good Luck with it!
O
one_bad_5.0
New York
Feb 16, 2008
  • Feb 16, 2008
5spd GT said:
Two guesses:
- New wheels
Good Luck with it!
E
El Horsepower
15
  • Feb 16, 2008
so what can I do if its the wheels?
D
Dark_Pony94
36
  • Feb 17, 2008
You can put steering rack limiters in to shorten your turning radius. I have them in mine and the rims dont rub the control arms anymore
E
El Horsepower
15
  • Feb 19, 2008
how hard are they to install?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Feb 19, 2008
  • Feb 19, 2008
You just have to slip them over something (I dont remeber what, but someone will). It takes a few minutes.
D
Dark_Pony94
36
#10
  • Feb 20, 2008
  • #10
You slide the boots off your rack and just clip them in and slide the boots back on. Takes about 5 minutes really easy to do.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Feb 20, 2008
#11
  • Feb 20, 2008
  • #11
Where can you get these, I need them BADLY!
D
Dark_Pony94
36
#12
  • Feb 20, 2008
  • #12
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=1333
There ya go, you can also goto your local dealership but they are a special order from
If anyone needs pictures I can take some for you
E
El Horsepower
15
#13
  • Feb 20, 2008
  • #13
Pics would be awesome, I would love a reference point!
D
Dark_Pony94
36
#14
  • Feb 21, 2008
  • #14
Alright, above you have the boot on the passenger side of the rack. You'll need to remove the clamp on it by squeezing it with a pair of pliers. Then slide the boot to the side.
This is what you'll see underneath. You'll need to get both boots out of the way and turn the steering wheel to one side. Turn to the right to work on the left and vice versa. Then pretty much push the limiters onto the shaft. Put the boots back on with the clips and your done. Make sure to check the clearances before putting them back on tho no need to do it multiple times. If you can't get the clamps to go back on you can use zip ties as you can see in both pictures.
You should be ok with either one or two per side. I run three since my car is lowered and has wider wheels on it. Hope that helps ya out man. Any other questions feel free to ask!
E
El Horsepower
15
#15
  • Feb 21, 2008
  • #15
man i really appreciate those pics! This will help alot!
D
Dark_Pony94
36
#16
  • Feb 21, 2008
  • #16
not a problem dude. glad i could help
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
