Did they make an SVO with manual brakes??
5.0ina66
664
Ohio
Been looking at mastercylinders for my SVO rear disc swap and I found a mastercylinder from an 84 manual brake SVO that seems to be PERFECT. Only thing is it doesn't say "For 4 wheel discs". Did they make a manual brake SVO and did it still have 4 wheel discs?
Thanks
--Kyle
Here's the one you're talking about. The critical area is the cylinder bore. SVO is about the biggest you can get at 1-1/8". AFAIK all SVO masters are 1-1/8". The bigger bore is needed to provide more fluid to fill the calipers. I'm running a '95 Mustang GT master with 73mm calipers/11" rotors on the front and an '87 TC rear w/stock rear discs on the back. The '95 GT master has a 15/16" bore. More than enough.
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=A1C&mfrpartnumber=101906&parttype=230&ptset=A
