- Feb 18, 2004
- 84
- 0
- 0
sliver02GT said:i put a tb and a accufab intake on and i feel like i lost bottom end, is this common
thanks
I think they just meant the Plenum.RysRed96GT said:if the runners are short, you'll gain hp (high end power) and loose low end due to a reductin in the ram charging phenomenon. longer runners create more momentum of air, and hence, more torque (low end).
I'm with JonJon - especially with 4.10s, how would you notice? The 75mm TB reportedly mirrors the stock RWHP up until 3K+, while the 70mm has minimal gains throughout the range, but honestly, I don't see how this would be noticable.JonJon said:how do you feel such a small change
Rio96 said:>I feel low end loss in the 1500-2000 range.<
That statement is kinda suspicious...
at those RPMs, the predominant factor in engine performance is the timing of the closing
of the intake valve.
03trubluGT said:I personally can't tell anything in that range. Hopefully you don't spend very much time there so you won't feel that your investment is a total loss.
1500-2000 rpm is just a by product of getting to the upper rpm range where you make the meat and potatoes of your power.
Matt
