dies after starting
  • Thread starter Thread starter 287ridah
  • Start date Start date Jul 17, 2004
287ridah
  • Jul 17, 2004
89 5.0 GT Auto
Hey fella's
Took off from the house and my car choked then died. It started fine but died right after. Started it again and hit the gas, I was able to make it back to the drive way but it again died. It felt like it wasn't getting gas. It starts fine but dies after 1sec of running. Any thoughts??
Im mechanically inclined but fuel injection is new to me. Plugs are good. When I got the car two months ago I constantly heard a whine from the gas tank, which I figured was the fuel pump. Could a whine be a sympton of bad fuel pump?
Basically my question is how to go about searching for the problem. Im going to check the usual, cap, rotor, plugs, batt, etc
THis is probably a easy question but I figured Id ask since fuel injection cars are new to me and the chilton manual sucks ass in this region.
Thanks for any help
R
ratrapp
510
buena vista,va
Jul 17, 2004
  • Jul 17, 2004
you'll need a fuel pressure gauge to check fuel pressure(bad pump or clogged fuel filter)if that's ok suspect the inertia switch in the back of the hatch.try resetting it or sometimes they just go bad without tripping themselves.also could be the relay under the drivers seat.
287ridah
  • Jul 17, 2004
I'll try that.
Last week I changed the fuel filter by the gas tank.
THanks for the advice
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
