  • SN95 4.6L Mustang Tech
diff. between crown vic 4.6 and mustang 4.6
  • Thread starter Thread starter TNstanggurl
  • Start date Start date Nov 22, 2004
T
TNstanggurl
153
TN
Nov 22, 2004
  • Nov 22, 2004
Just wondering what all the differences are between the crown vic 4.6l and the mustang 4.6l?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 22, 2004
  • Nov 22, 2004
crown vics didnt get the PI heads and intake until 01. they got the coil on plugs in 98. the plenum faces the other way. other than that they are the same.
CanadaStang
2,093
Mb
Nov 22, 2004
  • Nov 22, 2004
The PI Crown Vics are only 235 HP with the dual exhaust, so I would think the cams my be different, someone correct me if I'm wrong
R
raykrv6a
153
Maple Grove, MN
Nov 23, 2004
  • Nov 23, 2004
Same PI Cams. Intake, Exhaust, and the Mustang gets the Ford HP tune. That's my prime motivation to change cams. Burns me that the same cams are used in the CV's and die at 5200. VT Stang I's have the same hp curve up to 5200, but keep on putting out more power until 6 grand or so.
USMC03GT
144
Jacksonville, NC
Nov 23, 2004
  • Nov 23, 2004
I was thinking that maybe ford had put some geezer cams in the CV . But it makes sense that they use the same ones in the cv and mustang...saves money
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 23, 2004
  • Nov 23, 2004
I don't think that CV's are true dual exhaust either. I believe that they're 2-1-2, which doesn't flow nearly as well. Aside from the above mentioned, there’s also the computer tune and not to mention the portly 4300lb weight and different torque converter not putting the same power to the ground.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Nov 23, 2004
  • Nov 23, 2004
no CV's are true dual, well as true as a mustang is. there are exhaust manifolds, then pipes with cats, then an H pipe and the mufflers. the single exhaust version has a Y pipe. the CV's with the handling and performance package 239hp and about 278tq. the tune is more conservative than a mustang, more geared to the larger size and heavier weight of the crown vic.
Q
Resolved 96 crown Vic ECU in a mustang gt
  • QuickDibbles
  • Aug 30, 2025
SN95 4.6L Mustang Tech Sep 27, 2025
99 mustang gt 4.6 excess cooling system pressure
  • Blackbeauty99-4.6
  • Nov 11, 2026
SN95 4.6L Mustang Tech Nov 21, 2026
Mustang5L5
J
2004 mustang 4.6 timing cover
  • jk66
  • Jun 26, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
C
4.6 2V Plastic Intake Manifold Failure / Replacement / Alternatives
  • ctandc
  • Wednesday at 10:23 PM
SN95 4.6L Mustang Tech Wednesday at 10:23 PM
ctandc
C
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
