  • SN95 4.6L Mustang Tech
Diff. Pressure Sensor
  • Thread starter Thread starter mustanggt3685
  • Start date Start date Jan 27, 2006
M
mustanggt3685
130
Illinois
Jan 27, 2006
  • Jan 27, 2006
Hey guys...I keep getting a P1405 code thrown from the computer...so I guess it is a Differential pressure sensor failure. Where is that at? I hear it is an easy fix but I honestly have no clue where to start looking. Thanks!:SNSign:
sgarlic
3,085
Jan 28, 2006
  • Jan 28, 2006
P1405 - DPF EGR Sensor - Upstream Hose Off or Plugged
Description:
While driving, the EGR monitor commands the EGR valve closed and checks the differential pressure across the EGR orifice. The test fails when the signal from the DPF EGR sensor indicates EGR flow is in the negative direction.
Possible causes:
Upstream hose disconnected
Upstream hose is plugged (ice)
Plugged or damaged EGR tube
Look for signs of water or icing in hose. Verify hose connection and routing (no excessive dips)
Verify DPF EGR sensor proper mounting and function (view DPF EGR PID while applying and releasing vacuum directly to sensor with a hand pump)
Pearl02
496
Kansas City
Jan 28, 2006
  • Jan 28, 2006
I think it on the drivers side near the firewall. It's a black box with two different size hoses connected to it. These things go bad because exhaust gases flows thru it and condensation corrodes the insides of the sensor. It's pretty easy to test if you have a volt meter and a vacuum gauge. I had the same problem with my Mazda B4000. Follow what Sgarlic has stated. You can also do a search on the internet about checking it. Pearl02.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jan 28, 2006
  • Jan 28, 2006
It's a rectangular shaped piece near the EGR...mine was aluminum in color.
M
mustanggt3685
130
Illinois
Jan 28, 2006
  • Jan 28, 2006
Yeah when I did the PI intake I had to delete the water pump hose that runs into the heater core. Well not delete technically, but I took the old hose out and I ran a piece of thick tubing to the heater core from the water pump. I know I know ford makes the part to fix that, but I am cheap and impatient. WOuld that have anything to do with it?
Pearl02
496
Kansas City
Jan 29, 2006
  • Jan 29, 2006
Yea, they use to be aluminum in color. I believe Ford changed the old aluminum cases. When you buy a new one, it'll be black. Pearl02.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
