differances in distributors
  • Thread starter Thread starter noslow1986
  • Start date Start date Nov 3, 2006
N
noslow1986
274
oswego Il
Nov 3, 2006
  • Nov 3, 2006
whats the differance in the 5 speed or auto distrbutors. or is there a differance in the pick up on auto and 5 speed
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 3, 2006
  • Nov 3, 2006
auto and 5 speed = same distributors
N
noslow1986
274
oswego Il
Nov 3, 2006
  • Nov 3, 2006
are the pick ups in the distributors different
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 4, 2006
  • Nov 4, 2006
I wouldn't think so....I have never heard anyting about that and all the guys on here who have gone from auto to manual have never said anything about this.....and when you buy a new or aftermerket dizzy they are not auto or manual specific
N
noslow1986
274
oswego Il
Nov 4, 2006
  • Nov 4, 2006
wow im just tring to narrow my problems down i have a bad miss at 4000. i got the timing done. i switch out motors and put a 91 motor in it. and the 91 motor was from an auto car. vacuum lines good, plug, wires cap and rotor all new. theres someting loose somewhere just havent found it yet. it happens when i go over bumps and hit about 4000 grand or more, its sputters and almost lose power then it corrects its self. who knows damn fords
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 4, 2006
  • Nov 4, 2006
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
joel5.0
429
Puerto Rico
Nov 4, 2006
  • Nov 4, 2006
Distributors are the same....the TFI module comes in auto tranny setup (Computer Controlled Dwell TFI) and manual (Push Start TFI) versions.....check http://webpages.charter.net/chrisstephens/EEC Help files/Files/TFI_grey_or_black.html ...but start with the self-tests.
N
noslow1986
274
oswego Il
Nov 4, 2006
  • Nov 4, 2006
its says canister purge and code 67 im using an auto computer i will have to check it later
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine How to identify EEC-IV
  • keel
  • Aug 17, 2025
Fox 5.0 Mustang Tech Sep 1, 2025
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
