Difference between 65 and 67 V8 drum spindles?
  • Thread starter Thread starter tillerman85
  • Start date Start date Mar 20, 2006
T
tillerman85
39
  • Mar 20, 2006
Hi,
Can anyone tell me the difference between a 65 v8 drum spindle and a 67. I have a Baer brake kit I'm installing and it is the kit for 65-66 drum spindles.
As I am installing it I learn my car has 70 spindles (bigger bearings) on it. I am having a hard time finding 65-66 spindles locally. I know that the bearings are the same but I've heard that the camber is different between the two. I also have a concern about the steering arm (longer/shorter?) since I have the Baer bumpsteer tie rods also.
Thanks for the help.
degins
361
Texas
Mar 20, 2006
  • Mar 20, 2006
tillerman85 said:
Hi,
There are two differences. The tie rod mount hole is a bit larger on the 67 spindle, and the 67 spindle has a small difference in the steering arm geometry. The 67 has same steering geometry as 68-73 and Granada.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 20, 2006
  • Mar 20, 2006
I suggest you keep the 70 spindles as they are very desirable and whoever put them on should have made other changes for them to work. If you change them you will probably find that tie rods and other parts have been swapped also. Just exchange your brake kit for a 70.
NPD has a limited supply of 70 spindles that are selling for $259 each! The larger bearings and sturdier spindle design is much better than earlier models.
T
tylerdru
15
  • Mar 20, 2006
Go figure i just threw my spindles away. I would have sold them to you pretty cheap.
D
danny clemens
728
  • Mar 20, 2006
If you go back to the 65/66 spindle you'll have to replace the outer tie rod. If the inner tie rod has been shortened you may have to replace that as well.
T
tillerman85
39
  • Mar 22, 2006
Thanks Guys.
It's too late to exchange the brake kit. I guess I need to find some 65-66 spindles. I thought 67's might work, but after Danny Clemmens post, along with the uncorrectable toe in I have, I think the tie rod hole (steering arm) is in a different location on all but 65-66. I can't just change the tie rods because I already have the Baer tie rods for 65-66.
Anyone need a set of detailed 70 drum brake spindles?.......
Thanks again.
LMan
1,246
Mom's basement
Mar 22, 2006
  • Mar 22, 2006
You should have no trouble selling those.
RMODEL65
313
brunswick ga
Mar 22, 2006
  • Mar 22, 2006
tillerman85 said:
Thanks Guys.
Thanks again.
www.mustangmasters.com freddy sells used parts and new repo!
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
WTB [WTB] 1967-1970 Mustang Fastback
  • Brett_F
  • Jun 19, 2025
  • Want to Buy
Want to Buy Jun 19, 2025
Brett_F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
