difference between OEM and FRPP clutch cable?
  • Thread starter Thread starter Pur Pony
  • Start date Start date Mar 27, 2009
P
Pur Pony
112
CT
Mar 27, 2009
  • Mar 27, 2009
Looking for a new OEM clutch cable for my fox and they want $140+ for a cable. The FRPP cable is $70. Whats the difference in quality? I heard the OEM is the best.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 27, 2009
  • Mar 27, 2009
I may not be the best advice but what kind of clutch do you have? I always read on here to not go adjustable but I've used an oem non adjustable one from buyfordracing.com for like 40 bucks (read sticky before you buy from them though) It snapped after about a year. I went with a cheap parts store one for like 30 bucks, and that one snapped in less than a year, and I bought another parts store one and have been running it with no problem for a about 6 months, and hasn't stretched yet. Im not sure what the problem was, I have a king cobra clutch and a Maximum Motorsports firewall adjuster. It would just keep stretching and I had to keep adjusting it with the firewall adjuster until it wouldn't adjust anymore and it would just snap. I was told by a mustang friend to go with a ZOOM adjustable, pretty sure you can order them for like 80 bucks at advance. Hope that helps. I wouldn't spend 140 bucks on a cable though.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Mar 27, 2009
  • Mar 27, 2009
ive been down this road. my suggestion is to get the Maximum motorsports clutch cable and a FWA and you wont have any problems.
P
Pur Pony
112
CT
Mar 27, 2009
  • Mar 27, 2009
I will be using a Mcleod RXT twin disc. I already bought the richard racing micro-click FWA. Its sweet as hell. No idea if the MM cable will work with that. They say it will only work with their adjuster.
LiquidGT
368
Near STL hell
Mar 27, 2009
  • Mar 27, 2009
I've put 10k DD miles on this and it seems to be holding up well.
Ford Racing M-7553-A302 - Ford Racing Clutch Linkage Upgrade Kits and Accessories
+1 on the micro-click FWA, I wouldnt buy any other kind.
5.0TailPipeHump
153
Mar 27, 2009
  • Mar 27, 2009
I used the ford racing cable for 30 thous miles and its still holding up with my hays clutch, its a good cable.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Mar 27, 2009
  • Mar 27, 2009
It's more than likely the same as the ford oem part.
There is alot of parts that are cheaper as a ford racing parts than a regular oem part, even though they are 100% identical.
I also feel if you are breaking clutch cables, something is wrong.
I broke one, in 17 years, and that only happened because i installed headers myself and the header burnt the cable.
Also includes 5 or so differenent clutches, one of which wore the hell out of my leg it was so tough.
Certain clutches sometimes benefit from a slight spacing of the pivot ball, and or an extended fork.
93 LX
3,081
Norwalk, CA.
Mar 28, 2009
  • Mar 28, 2009
Not true the one i got in a ford box was a cheap cable. Ordered the MM cable and adjusters.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Mar 28, 2009
  • Mar 28, 2009
i used a FRPP cable and it worked good for a while but it broke after a while.
its not the same as the OEM cable. the FRPP has an adjustable ball end down by the tranny. so a FWA isnt need with it.
GT_Rich
172
North Canton, OH
Mar 28, 2009
#10
  • Mar 28, 2009
  • #10
I, too, have been down this road. I originally started out with a Ford Racing cable, Ford Racing quadrant, and a BBK adjuster. The Ford Racing quadrant was a nicely machined piece, but the geometry was poor. I had rubbing issues and no adjustment left with my cable (cable was too short). I went with a MM cable and MM quadrant, kept the cheap adjuster, and this setup has been great. The MM cable (Ford OEM) is definitely different than the Ford Racing cable. I would highly recommend it. It should work with many different combos.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
