- Sep 26, 2009
- 6
- 0
- 0
what is the difference between a 1985 and older 5.0l flywheel and a 1986 and newer? does it also work the same way for a 5.8l? if not, what type of flywheel would i need for a 1984 5.8l? not sure what type of vehicle it came out of. i had a 1985 5.0l ho. flywheel on it untill i placed it back on the 5.0 to custom fit it into a chevy s10 with the t5.
, and now need to buy a flywheel and clutch for my 5.8. for the sake of price, im looking to buy one for a 5.0 (knowing its compatible with the 5.8) for the 5.8. i only recently relized there are different sizes, imbalance weights, and teeth within the different years (guess i got lucky with the miss matching). what i understood with my research was, the 85'earlier had 28oz weights 10" clutch 157spline ring gear(so im assuming the 5.8 needs a 28oz), and the 86' later has 50oz weights and a 10.5"clutch 157spline ring gear (PLEASE correct me if im wrong) soooo.... my question is: would it work with the 351w to to get a 86 or later flywheel with a bolt on "28oz" weight and a 10.5" clutch (the bigger the clutch, the better, right?)and still use the same bellhousing and starter that i had with the 85" setup? if not, what would work, or be recommended?
