Difference in foxbodys?
zZsKyZz
503
As you guys can see, I own a SN95. I have a 302 sitting in my garage that I plan on building and either putting in my 94 stang or buying a cheap (hopefully for around $500ish) fox-body (86-93) and putting the engine in it. My question is what will this 302 bolt right up to? it's out of an 88 GT.
There is a 89ish (guessing) fox body mustang near my house that is a 4cyl and he wants about $1000 for it but I think I can talk him down if I show up with cash, my question is what will I need to change? Is the rear the same or is it a 7.5 like the 94+ mustangs? will the transmission be the same?
What should I be looking for for my project?
Thanks!
7.5 was in 4cyl. fox's. I am not sure if the 94+v6's still had the 7.5 the gt/cobra had a 8.8.
If its a 5spd then you will be golden as the 4cyl t5 is really a nice trans. IIRC it has the 2.9x 1st. If its an AOD then it will prob. be just alittle overpowerd :rlaugh: but I really dont like ford autos (cept c6).
you will need a v8 harness things that go along with that and the inj. if you dont have a set around.
i would tear down the block and build a 347 to slap in your car.
what would be the point of have a stock fox body after all that work converting it to a v8
