I am in the process of recovering a set of hi- back sport seats. All went well until I did the back of the front seats. My question is -- what holds the top of the large rods that are inserted from the bottom up through the foam and across the horozontal rods? The LMR article says"
Once you have the horizontal rod pointing in the right direction, start re-inserting the large rods. This is sort of tricky. You have to make sure the horizontal rod cradles it correctly and also make sure you get it under the "HOOK" that is way up in there by where the headrest is.
I dont have any piece that looks like a hook??
Without that rod being held toward the back of the seat, the seat material seems to push out rather than be recessed as it should be.
Any ideas about what I don't understand or where I am going wrong on this procedure?
