Exhaust Difficulty of fixing exhaust leak at manifold
  • Thread starter Thread starter dqureshi06
  • Start date Start date Aug 27, 2026
D
dqureshi06
102
21
28
Virginia
Aug 27, 2026
  • Aug 27, 2026
So I have leaking exhaust where the midpipe meets the headers on both sides, but the ticking noise from the leak is coming from the drivers side. I’m planning to fix it this week. I was wondering if any of you have had luck fixing these leaks without unbolting the headers from the cylinder head, and instead adjusting the midpipe by loosening it from both sides. Midpipe and headers are both BBK, by the way.
DadLife0724
I vote for a new bung hole.
Mar 22, 2024
425
285
73
Cooperstown, PA
Aug 27, 2026
  • Aug 27, 2026
Get them warm and let them cool a little and then try tightening them up. I got rid of a tick on my fox that way. Don't hammer them down too hard but you will probably get some movement.
General karthief
Mod Dude
Aug 25, 2016
28,105
10,717
213
polk county florida
Aug 27, 2026
  • Aug 27, 2026
Ball and socket connection?
Do you see where it leaks?
AeroCoupe
6,182
4,279
183
Claremore, OK
Aug 27, 2026
  • Aug 27, 2026
If it’s been going on for a while the gasket may be toast, literally. If the headers are unequal length you may spend more time trying to adjust things than just pulling them and replacing gaskets. I’m not saying do t try but just be prepared.
Speaking of gaskets when gaskets did you use?
keel
280
128
53
Seattle, Wa
Aug 27, 2026
  • Aug 27, 2026
I have had good luck getting header gaskets and ball and socket joints to seal better by putting a thin film of high temp copper gasket maker on the mating surfaces. You still need the actual gasket though for the headers.
Reactions: General karthief
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,517
2,938
173
Florida
Aug 28, 2026
  • Aug 28, 2026
Any of your local muffler shops have one of the giant belt sanders?? Not sure if you can do headers on one but getting my exhaust manifolds surface " planed" by one of these huge sanders does wonders for them...
rednotch
I'd like to remain having one chocolate starfish
1,476
685
143
south jersey
Aug 28, 2026
  • Aug 28, 2026
Bbk ball and socket system is terrible for leaks, you may need to either expand the ball on the header or compress the socket on the mid pipe and load it with red or copper rtv, I cut them off at this point if there long tubes and use a v band or Torca clamps like these branded under Holley, many OEM's use those these days now. https://www.holley.com/products/exhaust/builder_components/brackets_and_clamps/parts/41172HKR. Don't confuse the torca clamps with cheap ass band strap clamps there no where near the same.
Reactions: dqureshi06
D
dqureshi06
102
21
28
Virginia
Aug 28, 2026
  • Aug 28, 2026
So I need to remove the headers from the cylinder head?
KRUISR
1,876
1,014
143
Aug 28, 2026
  • Aug 28, 2026
It depends where the leak is coming from. If the header to mid pipe flange is leaking, fix that. If it is leaking at a specific port, then probably best to remove the header, clean the head surface and install with new gasket.
Reactions: DadLife0724 and keel
D
dqureshi06
102
21
28
Virginia
Aug 28, 2026
#10
  • Aug 28, 2026
  • #10
Yeah it’s at the mid pipe flange. I already leak tested it
General karthief
Mod Dude
Aug 25, 2016
28,105
10,717
213
polk county florida
Aug 28, 2026
#11
  • Aug 28, 2026
  • #11
Take the mid pipe off the header and look for witness marks, you may need to massage the bell (socket) with the ball end of a ball peen hammer then slather the ball/socket with copper hi-temt exhaust goo and tighten evenly.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
