Dipstick Question
  • Thread starter Thread starter crunchie12268
  • Start date Start date Nov 7, 2004
C
crunchie12268
599
Manhattan, KS
Nov 7, 2004
  • Nov 7, 2004
My dipstick is very loosley connected to the side of my block. I can pull it out and read my oil level and everything. It never falls out when driving and now oil leaks from it. Does this need to be sealed? This isn't hurting my performance in any way is it? Is it just giving me better crankcase ventillation?
V
v8only
2,378
22
49
Nov 7, 2004
  • Nov 7, 2004
It should push in snugly and need NO sealant of any kind. Shine a flashlight down there and see what's going on, be sure the dipstick is fully seated.
there is a chance it could be broken too. the end of the dipstick tube is double flanged, so if you pull the housing to the tube off, and only see one flange at the bottom, then it's broken off inside. If that's the case, don't stress. Forgot the name of the tool, but you bang it into the hole and turn it out with a ratchet, and the broken section comes right out.
also, the dipstick is supposed to bolt to one of the header bolts, and if you have aftermarket headers, then it likely is not anymore, however, it should still NOT leak.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
